Please forgive me for writing in English - I hope it is ok. I need help about the numbers on the bearing caps, se the enclosed photo. There is stamped "D2K-A STD" and typed "3" in black, but which of these numbers refer to the numbers in the spares list or manual (1-5)? And what does D, K and A mean? On some of the other caps is written D3H-A , D4D-A or D4E-A.
And can these bearings be bought in Europe?
Thanks for your help!
Kind regards
Jørn
Crankshaft bearing caps
- Bearing cap.jpg (100.75 KiB) 38822 mal betrachtet
Re: Crankshaft bearing caps
Die einzige Nummer, die du brauchst ist die geätzte 3. Die anderen sind uninterressant. Die 3 in diesem Fall bezieht sich auf die Dicke der Lagerschale.
Hi Jorn,
do you need bearing for connecting rod or for crank shaft ?
341-11656-20 (3) connecting rod
341-11416-20 (3) crank shaft
regards Torsten
regards Torsten
Hi Torsten, I need bearings for the crankshaft, 341-11416-xxx, do you know where to find them?
But I also need to investigate if I need to have the crankshaft journal reground. Do you know, if untersize bearing caps are available?
Hast du kein Werkstatthandbuch? Darin ist genau beschrieben, welche Lagerschalen du brauchst. Im Ersatzteilkatalog findest du dann die richtige Lagernummer.
Hi Jorn,
part numbers and size
Regards Torsten
Regards Torsten
